#1 29-09-2018 17:40:38
WarZone2100 - Sauvegarde erreur
Salut tout le monde entier de l'univers intergalactique !!!
Voila aujourd'hui mon filston a voulu lancer une sauvegarde dans WareZone2100 puis le jeu plante...
Dans le terminal :
tyzef@debian:~$
warzone2100
info    |05:55:52: [realmain:1146] Using /home/tyzef/.warzone2100-3.2/logs/WZlog-0929_175552.txt debug file
Cannot connect to server socket err = Aucun fichier ou dossier de ce type
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for 4294967295, skipping unlock
error   |05:56:12: [initTemplates:210] Template  from stored templates cannot be designed
last message repeated 2 times
last message repeated 2 times (total 4 repeats)
last message repeated 4 times (total 8 repeats)
last message repeated 8 times (total 16 repeats)
last message repeated 16 times (total 32 repeats)
last message repeated 32 times (total 64 repeats)
last message repeated 64 times (total 128 repeats)
last message repeated 128 times (total 256 repeats)
last message repeated 256 times (total 512 repeats)
last message repeated 512 times (total 1024 repeats)
last message repeated 1024 times (total 2048 repeats)
last message repeated 2048 times (total 4096 repeats)
last message repeated 4096 times (total 8192 repeats)
last message repeated 8192 times (total 16384 repeats)
last message repeated 16384 times (total 32768 repeats)
last message repeated 32768 times (total 65536 repeats)
last message repeated 65536 times (total 131072 repeats)
last message repeated 131072 times (total 262144 repeats)
last message repeated 262144 times (total 524288 repeats)
last message repeated 524288 times (total 1048576 repeats)
last message repeated 1048576 times (total 2097152 repeats)
last message repeated 2097152 times (total 4194304 repeats)
Processus arrêté
tyzef@debian:~$
Processus arrêté car une petite fenêtre qui me dit que l'application ne répond pas...
Une idée ?
Me dites pas qu'on est en 2018 et qu'il faut attendre 2100 hein !!! eh eh !
Merci.
Edit à toto : Séparer la commande de son retour est plus lisible pour les plus débutants intéressés par le post. wink
#2 29-09-2018 21:33:26
Re : WarZone2100 - Sauvegarde erreur
Que donne ?
cat /home/tyzef/.warzone2100-3.2/logs/WZlog-0929_175552.txt
#3 30-09-2018 12:29:32
Merci Otyugh !
Voici :
 tyzef@debian:~$ cat /home/tyzef/.warzone2100-3.2/logs/WZlog-0930_162201.txt
--- Starting log [/home/tyzef/.warzone2100-3.2/logs/WZlog-0930_162201.txt]---
info    |04:22:01: [realmain:1146] Using /home/tyzef/.warzone2100-3.2/logs/WZlog-0930_162201.txt debug file
error   |04:22:38: [initTemplates:210] Template  from stored templates cannot be designed
tyzef@debian:~$
Dernière modification par TyZef (01-10-2018 06:01:40)
